Get the names of layouts at Cyrillic
Hi!
I try to receive names of layouts at Cyrillic (Russian & Ukrainian symbols), but when i output names to "Session Reporter", I receive garbage like
@825B.
Look attachment for more information.
1 - Layouts names at "Navigator - Layout Book"
2 - Output to "Session Reporter"
Look at my code here: http://pastebin.com/eHEGCT0g
Advance thanks
ReignBough
Does "Session Reporter" supports UNICODE?
Have you tried using OutputDebugStringW() and _swprintf() instead of ACAPI_WriteReport()?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
The name has unicode characters (GS::uchar_t), but you casted them to normal characters (char). That's why you lost cyril symbols and get garbage.
Instead of this code:
char* name = new char[API_UniLongNameLen];
for(GSIndex i = 0; i < API_UniLongNameLen; i++)
        name = (char)(api_dbPars.name);
        if((char)api_dbPars.name == '\0') { break; }
ACAPI_WriteReport((char*)(name), false);
delete[] name;
Please use the following:
GS::UniString name (api_dbPars.name);
ACAPI_WriteReport(name.ToCStr ().Get (), false);
It's much shorter and works great. 😉
Best Regards,
Tibor Lorántfy
