Get the selected element
Hi.
I select an element on first level.
I want to get the element after I switch to the second level.
ACAPI_Selection_Get the api does't work.
How can get it ? thanks.
1 Solution
How about:
1) Use ACAPI_Selection_Get first to collect the selected elements
2) Extract whatever data you need from the selection
3) Search for the elements that should receive the new data
4) Apply the data to elements (on whatever floor)
Ralph Wessel BArch
Central Innovation
Go to post
4 Replies 4
I assume you're working in the floor plan view? If so, ACAPI_Selection_Get can only get elements that are currently selected – if you can't select it as a user, this function won't retrieve it either. Can you describe the workflow you're trying to achieve? There might be a better solution.
Ralph Wessel BArch
Central Innovation
Yes,I'm working in the floor plan view.
I want to copy the properties of the selected element to other elements on another level.
Thanks.
How about:
Ralph Wessel BArch
Central Innovation
Ralph wrote:
How about:
Thanks.
