poco2013
Mentor
Global Variables
Just wondering if it would be possible to create a series of global variables or properties which could be accessible by any other ADD-Ons and exist for the life of the Plan?
If so, could those same global properties be used to reference that info within a standard schedule?
The purpose of such "global" properties would be to accumulate such plan wide information such as area analysis , quantities, costs. etc. etc.
Gerry
4 Replies 4
Ralph Wessel
I don't think it's possible for an add-on to create project-based data that can be directly accessed by other add-ons. And it wouldn't be safe for multiple add-ons to modify that data without a common mechanism to manage it.
An add-on could provide access to the data via an external command or service, i.e. other add-ons could call it to get/set data if it provided a published command set.
However, I don't see any way for that data to interact directly with ARCHICAD's scheduling. There is no API to inject schedule content (to my knowledge).
Ralph Wessel BArch
Central Innovation
poco2013
Mentor
Thanks Ralph
That's somewhat what I expected. But I found it useful in other programs, but -- yes- it can be a disaster if the user is not aware, particularly if multiple plans are open at the same time.
Still think it would solve a number of problems if used with caution.
Gerry
Akos Somorjai
If you aim for model element specific properties, then please take a look at the Properties API (new in ARCHICAD 20). These are accessible from all add-ons, can be created by one add-on, or put directly by a BIM Manager into the company template. Also, you can show them in schedules, export and import them to/from Excel, etc.
Regards, Akos
poco2013
Mentor
Thanks Akos
Yes --using properties, I am able to accumulate cost data for various object and summarize the same within schedules. Simply by following and a sight modification of the Property_test example in the API examples.
And by using "phantom" objects with their properties used as accumulators i am am to achieve the same. But, I think, user read/write GLOB variables would still be a more direct and understandable approach.
Gerry
