Archicad C++ API
Handle events from browser control DG::Browser
Martin Walter
How can I recognize an event from the browser control DG::Browser, for example the URLChanged which is declared in BrowserBase?
AC22-27, Windows 11, i7-1355U, 32GB RAM, 2TB SSD
Martin Walter
Obviously the callback function can not be defined in a class. I got it working finally this way:
void handleURLChanged(const DG::BrowserBase& source, const DG::BrowserURLChangedArg& eventArg);
m_browser.urlChanged += DGEventNotifier<DG::BrowserBase, DG::BrowserURLChangedArg>::Runnable(&handleURLChanged);
6 REPLIES 6
Use the += operator of BrowserBase::urlChanged to add a Runnable callback function to respond to this event.
Ralph Wessel BArch
Central Innovation
Martin Walter
Sorry I'm not able to make it. My code does not compile in this line:
DGEventNotifier<BrowserBase, DG::BrowserURLChangedArg>::Runnable func = &UIBrowser::URLChanged;
Can you please tell me what is wrong?
My whole code is:
class UIBrowser: public DG::Browser
public:
	UIBrowser(const DG::Panel& panel, short item);
private:
	virtual void URLChanged(const DG::BrowserURLChangedArg& eventArg) override;
UIBrowser::UIBrowser(const DG::Panel& panel, short item) :
	DG::Browser(panel, item)
	this->urlChanged += func;
void UIBrowser::URLChanged(const DG::BrowserURLChangedArg& eventArg)
Try changing this to:
this->urlChanged += DGEventNotifier<DG::BrowserBase, DG::BrowserURLChangedArg>::Runnable(UIBrowser::URLChanged);
Ralph Wessel BArch
Central Innovation
Martin Walter
that doesn't compile too.
and neither:
this->urlChanged += DGEventNotifier<DG::BrowserBase, DG::BrowserURLChangedArg>::Runnable(&UIBrowser::URLChanged);
The urlChanged function should look more like this:
void UIBrowser::URLChanged(const DG::BrowserBase& source, const DG::BrowserURLChangedArg& eventArg)
Ralph Wessel BArch
Central Innovation
Martin Walter
