Archicad C++ API
How I can get polygon of the not square window in the wall?
I need to get polyton of the rounded or other not square windows in the wall.
Where I can it find?
Thank You.
Our approach has been to examine the 3D model faces of the wall. If you cut the wall face with the window against the wall face without the window, the difference is the opening shape.
Ralph Wessel BArch
Central Innovation
Into the AC library there folder which is called "special windows"
Into this folder there is a parametric window with 3 sides or more
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
I'm know how place that windows.
But I need to get it's form by API C++.
Ralph Wessel BArch
Central Innovation
