2019-01-02
02:52 PM
2022-10-04
04:46 PM
Daniel Kassai
Solved! Go to Solution.
2019-01-18 10:19 AM
Tibor wrote:So how can I have these properties with their values in my imported library object when I place an instance of it? Is it possible?
n.mihaylov wrote:It's right.
when I place an instance of it I will have the properties with no values again, like in the case of a wall, right?
2019-01-18 10:35 AM
2019-01-18 10:50 AM
2019-01-18 11:05 AM
n.mihaylov wrote:Yes, but also keep in mind that any element with the same classification placed before or after this event will also have the same properties, i.e. the classification change applies to the entire project (not just a single element).
So after I import the library object, I have to create and place an element of it and then when I add the properties to its classification, I will have these properties with their values in this placed element, right?
2019-01-18 12:12 PM
