arad
How to change the value of a label linked to a fixed named optional parameter in the API
I’m trying to modify parameters when creating a label.
How can I change the value of a symbol label that is linked to a fixed named optional parameter?
Changing it from the API_LabelType or by modifying the object parameters does not produce the expected result.
GSErrCode SetLabel(API_Element* elem, const GS::UniString& libpartName) {
	GSErrCode err = NoError;
	API_LibPart libpart = {};
	BNZeroMemory(&libpart, sizeof(API_LibPart));
	GS::ucscpy(libpart.docu_UName, libpartName.ToUStr());
	err = ACAPI_LibraryPart_Search(&libpart, false);
	API_ParamOwnerType   paramOwner = {};
	API_ChangeParamType  chgParam = {};
	API_GetParamsType getParams = {};
	paramOwner.libInd = libpart.index;
	err = ACAPI_LibraryPart_OpenParameters(&paramOwner);
	if (err == NoError) {
		err = ACAPI_LibraryPart_GetActParameters(&getParams);
			CHCopyC("iReferencePoint", chgParam.name);
			chgParam.realValue = 5;
			err = ACAPI_LibraryPart_ChangeAParameter(&chgParam); //can change parameter
			CHCopyC("AC_TextAlignment_1", chgParam.name);
			chgParam.realValue = 2;
			err = ACAPI_LibraryPart_ChangeAParameter(&chgParam); //cannot change parameter
			if (err == NoError)
		ACAPI_LibraryPart_CloseParameters();
	API_Element     label = {};
	API_ElementMemo labelMemo = {};
	BNZeroMemory(&labelMemo, sizeof(API_ElementMemo));
	label.header.type.typeID = API_LabelID;
	label.label.parentType = elem->header.type.typeID;
	err = ACAPI_Element_GetDefaults(&label, &labelMemo);
	TurnAutoTextFlagOff(); //This function is defined externally.
	labelMemo.params = getParams.params;
	label.label.labelClass = APILblClass_Symbol;
	label.label.parent = elem->header.guid;
	label.label.u.symbol.libInd = libpart.index;
	label.label.u.symbol.ownerType.typeID = elem->header.type.typeID;
	label.label.u.text.pen = 36;
	label.label.framed = false;
	label.label.textWay = APIDir_Parallel;
	label.label.textSize = 2.6;
	label.label.hasLeaderLine = false;
	label.label.pen = 36;
	label.label.arrowData.arrowPen = 36;
	label.label.createAtDefaultPosition = true;
	label.label.u.text.just = APIJust_Center; //not work
	err = ACAPI_Element_Create(&label, &labelMemo);
	ACAPI_DisposeElemMemoHdls(&labelMemo);
	return err;
1 Solution
Akos Somorjai
Hi Arad,
AC_ parameters cannot be changed from the API, as they are controlled directly from Archicad (see the GDL reference guide, section "Parameters for Text Handling").
It seems that the API currently ignores the text settings when you create a symbol label. So, my idea is to set the default parameters for a text label (including justification), then create the symbol label. (and set the defaults back if needed)
Best, Akos
Go to post
2 Replies 2
Akos Somorjai
Hi Arad,
Best, Akos
arad
Changing the default label settings first worked well.
Thank you very much, Akos.
