How to close ArchiCAD file?
I tried to close file 2 ways.
1. By Name:
IO::Location loc(fileName); //fileName has _bstr_t type
IO::File file(loc);
file.Close(); // return NoError
2. Close current project:
ACAPI_Automate(APIDo_CloseID); //return APIERR_REFUSEDCMD
But nothing happens. I have no ideas about closing now.
4 Replies 4
I have never tried any of these, but noticed that CloseID says it will not close if another add-on is active. I wonder if APIDb_CloseWindowID on the plan window would work, although the docs seem to indicate that this function is only for a 'custom window opened from the same add-on'.
I would have thought that a goodie or automate function would have been the answer.
Ralph? 😉
Hi, Karl
I tried next code:
API_WindowInfo windowInfo;
BNZeroMemory (&windowInfo, sizeof (API_WindowInfo));
windowInfo.typeID = APIWind_FloorPlanID; // and try APIWind_WorksheetID typeId also
windowInfo.index = 1;
GSErrCode err = ACAPI_Database (APIDb_CloseWindowID, &windowInfo);
But APIERR_REFUSEDPAR error code returns.
Ralph Wessel
1. By Name:
I haven't tried to explicitly close a project. I've used the method for opening a project, which implicitly closes the current project. Why do you want to close a project without opening another?
Ralph Wessel BArch
Central Innovation
Hi, Ralph
My Add-On monitors project file folder for changes. When file changed, monitor should make some actions with him and show some message boxes in ArchiCAD too.
Typically ArchiCAD not lock project file all time. But I try to close project to guarantee file not locked by ArchiCAD and my monitor works right.
I can to open template project for closing current, but it's need some seconds. I will try to find decision, for example ask user to close again.
Thanks a lot
