How to display the headers of the ListBox?
In my ListBox, it has Three headers.
DGListSetHeaderItemCount(dialId, item, 3);
DGListSetHeaderFlags(dialId, item, true, false, false);
DGListSetHeaderItemFlags(dialId, item, 1, DG_IS_CENTER|DG_IS_TRUNCMIDDLE, false);
DGListSetHeaderItemText(dialId, item, 1, "ID");
DGListSetHeaderItemFlags(dialId, item, 2, DG_IS_CENTER|DG_IS_TRUNCMIDDLE, false);
DGListSetHeaderItemText(dialId, item, 2, "Length");
DGListSetHeaderItemFlags(dialId, item, 3, DG_IS_CENTER|DG_IS_TRUNCMIDDLE, false);
DGListSetHeaderItemText(dialId, item, 3, "Has");
But They can not display all.
Why??
Akos Somorjai
You have to set the header item size as well with DGListSetHeaderItemSize.
Hope this helps,
Akos
ReignBough
When creating class-based list box with header, the list box is not created. Also when HasHeader() is called, it will return false whether headerFlag is set to Header or NoHeader.
SingleSelListBox (
    const Panel &       panel,
    const Rect &        rect,
    ScrollType          scroll = VScroll,
    PartialItemType     part = PartialItems,
    HeaderFlag          headerFlag = NoHeader,   <------------------
    short               headerSize = 0
MultiSelListBox (
    const Rect &        rect,
    short               headerSize = 0);
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
