How to edit parameters of the element on the scene
Seems like this piece of code is getting lights from the scene correctly, but the values are not saved into objects. What else am I supposed to do in order to change parameters on the element?
Thanks for the help.
GS::Array<API_Guid> elemList;
        ACAPI_Element_GetElemList(API_LampID, &elemList, APIFilt_OnActFloor, APIVarId_Light, APINULLGuid);
        for (const auto& e : elemList) {
            API_Element element;
            BNZeroMemory(&element, sizeof(API_Element));
            element.header.guid = e;
            if (ACAPI_Element_Get(&element, 0) == NoError) {
                element.lamp.lightColor = API_RGBColor{ 1.f, 0.f, 0.f };
                element.lamp.lightIsOn  = true;
1 Solution
Ralph Wessel
Use ACAPI_Element_Change to write the change back to the database.
Ralph Wessel BArch
Central Innovation
Go to post
2 Replies 2
Ralph Wessel
Ralph Wessel BArch
Central Innovation
Thanks! To make this post more helpful, you have to wrap the actual element changing logic into ACAPI_CallUndoableCommand because in another case you get APIERR_NEEDSUNDOSCOPE and no changes will occur.
