Archicad C++ API
SOLVED!
How to implement the rolldown ui dialog?
Hi.
I want to achieve a similar ui effect as the below png.
How can I do that by api?
1 ACCEPTED SOLUTION
Solution
Oleg
Look at DG_Test example.
BasicElementIconsRollDownDialog.hpp, BasicElementIconsRollDownDialog.cpp
6 REPLIES 6
Hello DevJeer,
I think it might be better to post an english screen capture.
I'm not english but it's the rule here to communicate only by this language.
Your picture is not understandable for a lot of us. 😕
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
Ok, thank you. This is the screenshot of the english version.
Hello,
Thanks about it nut I don't understand your aim. Can you develop it as fine as possible ?
Christophe - FRANCE
Christophe wrote:
Hello,
I'm so sorry that I didn't express my meaning clearly.
My aim is that I want to achieve the similar ui effect as the above picture by api.
Can you provide same example to me?
Thanks
Solution
Oleg
Thanks.
