Archicad C++ API
How to set a cursor in a dialog?
Hi
The documentation indicates that a custom form cursor can be set in the DG_MSG_MOUSEMOVE message. What is the mechanism to set a custom form cursor pls?
Thanks
Paul
Tibor Lorantfy
Hi Paul,
Here is an example to show you how to set your custom cursor:
/* To your Fix.grc resource: */
'GCSR'	32680	"Open hand cursor" {
		   "HandBig"	/* your picture name, so HandBig.bmp should be placed into the Images folder next to this Fix grc */
		   9	10		/* the cursor position in the picture */
		   0	128	128
/* To your source code: */
UISetCursor (ACAPI_GetOwnResModule (), 32680);		// DG.h should be included
As far as I know this works not only in DG_MSG_MOUSEMOVE message.
Best Regards,
Tibor
Thanks Tibor - this works well. (Took me a long to to get around to implementing it).
Paul
