Tuesday
Hello!
Does the new IFCAPI have any prerequisites that need to be set in order to be used? The code provided below, if added to the example project IFC_Test, will print:
TestApi(): 1 TestApi(): 2 TestApi(): 3 Number of attributes: 6 Attribute Name0: GlobalId Attribute Name0: Name Attribute Name0: Tag Attribute Name0: PredefinedType
However, the same code in my add‑on returns 0 attributes:
TestApi(): 1
TestApi(): 2
TestApi(): 3
Number of attributes: 0
Archicad version: 29.2.0 (5003)
SDK version: WIN.29.3100
Test function:
void TestApi()
GS::Array<API_Neig> aSelection;
API_SelectionInfo rSelectionInfo = {};
ACAPI_Selection_Get(&rSelectionInfo, &aSelection, false);
for (auto& rNeig : aSelection)
API_Elem_Head head{};
head.guid = rNeig.guid;
auto objectID = IFCAPI::GetObjectAccessor().CreateElementObjectID(head);
DBPrintf("TestApi(): 1\n");
if (objectID.IsErr())
ACAPI_WriteReport("TestApi(): CreateElementObjectID failed for element ", true);
return;
IFCAPI::PropertyAccessor propertyAccessor = IFCAPI::PropertyAccessor(objectID.Unwrap());
auto properties = propertyAccessor.GetAttributes();
if (properties.IsErr())
ACAPI_WriteReport("TestApi(): GetAttributes failed for element", true);
return;
DBPrintf("TestApi(): 2\n");
auto oIfcAttributes = properties.Unwrap();
DBPrintf("TestApi(): 3\n");
DBPrintf("Number of attributes: %zu\n", oIfcAttributes.size());
for (auto& rIfcAttribute : oIfcAttributes)
if (rIfcAttribute.GetName().IsEmpty()) continue;
if (!rIfcAttribute.GetValue().has_value()) continue;
DBPrintf("Attribute Name0: %s\n", rIfcAttribute.GetName().ToCStr().Get());
Operating system used: Windows 11 25H2
yesterday
I've asked the developer for support.
Regards,
Tamás
