Archicad C++ API
Import external detail
Dejmas
Hello developers,
my goal is to import an external DWG file as a drawing in a new detail window. This is very trivial to do as a user, but I am having an issue with doing it programmatically.
As I have understood in the documentation I can't just create a new drawing element and bind a link to it. I should rather use a call to DXF/DWG add-on and it is where I got stuck on.
I haven't found much about that. Just one example in the documentation where a dwg file is imported as lib part. So I tried similar to create a drawing. Can I get some advice from you?
Trying to run DXF/DWG add-on between APIDb_StartDrawingDataID and APIDb_StopDrawingDataID calls.
class IDFSession {
private:
	bool    inited;
public:
	explicit IDFSession() {
		inited = (ACAPI_Database(APIDb_StartDrawingDataID, nullptr, nullptr) == NoError);
	~IDFSession() {
		if (inited) {
			GSPtr outIDFData = nullptr;
			if (GetIDFData(&outIDFData, nullptr))
				BMKillPtr(&outIDFData);
	bool GetIDFData(GSPtr *outIDFData, API_Box *bounds) {
		if (!inited || outIDFData == nullptr)
			return false;
		bool ret = (ACAPI_Database(APIDb_StopDrawingDataID, outIDFData, bounds) == NoError);
		inited = false;
		return ret;
GSErrCode ImportDrawing()
	IDFSession  idfSession;                      // 1
	GSErrCode   ret = ReadAction();              // 2
	if (ret == NoError) {
		API_Box bounds = { 0.0, 0.0, 0.0, 0.0 };
		GSPtr   idfData = nullptr;
		if (idfSession.GetIDFData(&idfData, &bounds)) {    // 3
			CreateDrawing_UndoableCall(idfData, bounds);   // 4
		} else {
			WriteReport("No drawing data.");
	return ret;
static GSErrCode		ReadAction(void)
	API_ModulID	mdid = { 1198731108, 1322668197 };		// DXF/DWG add-on
	GSErrCode	err;
	double scale = 100.0;
	bool rebuild = false;
	err = ACAPI_Database(APIDb_ChangeDrawingScaleID, &scale, &rebuild);
	if (err != NoError) {
		WriteReport("Error in APIDb_ChangeDrawingScaleID: %s", ErrID_To_Name(err));
		return err;
	IO::Location dwgFileLoc;
	if (!GetOpenFile(&dwgFileLoc, "dwg", "*.dwg"))
		return Cancel;
	// call the Dxf add-on
	GSHandle parHdl;
	err = ACAPI_Goodies(APIAny_InitMDCLParameterListID, &parHdl);
	if (err == NoError) {
		IO::URL url;
		dwgFileLoc.ToURL(&url);
		API_MDCLParameter par;
		BNZeroMemory(&par, sizeof(par));
		par.name = "FileName";
		par.type = MDCLPar_string;
		char str[512] = { 0 };
		CHTruncate((const char*)url, str, sizeof(str));
		par.string_par = str;
		err = ACAPI_Goodies(APIAny_AddMDCLParameterID, parHdl, &par);
		if (err == NoError)
			err = ACAPI_Command_Call(&mdid, 'OOBJ', 1, parHdl, nullptr, true);
	ACAPI_Goodies(APIAny_FreeMDCLParameterListID, &parHdl);
	return err;
}		// ReadAction
I am not sure about my command call, maybe I just need a different cmdID. I haven't found any documentation for it. Maybe I should focus on if I can use a lib part to create drawing from. I will be glad for every opinion.
Thank you for your attention.
1 REPLY 1
Ralph Wessel
Mentor
Your overall process (using the existing DXF/DWG importer) is correct. I've only used this add-on through the API for creating library parts (as the example shows), so I can't say for sure that it can import as a plain drawing. However, if you don't find any way to make that work, you could place the DWG as a library part and then use the API to explode it into constituent parts, e.g. ACAPI_LibPart_ShapePrims or ACAPI_Element_ShapePrims.
Ralph Wessel BArch
Active Thread Ltd
