Archicad C++ API
Importing exported consignation xml
eptar
Is it possible to import list definition xmls via code? As far as I know features related to the topic are handled by the InteractiveSchedule.apx. Is there a way to call the import function of that apx? Or the only way of importing is to make the user to do it?
Viktor Kovacs
At the moment it is not possible to call that functionality from an Add-On.
1 REPLY 1
Viktor Kovacs
