2020-07-31
		04:08 AM
		2021-09-15
		10:30 AM
			Noemi Balogh
Solved! Go to Solution.
2020-08-13 05:29 AM
2020-07-31 04:16 AM
2020-07-31 05:47 AM
Barry wrote:Is there an API to unload it?
Use the Add-on Manager in Archicad.
This will allow you to load or un-load add-ons without actually removing the files.
Or close Archicad and you should have full control of the actual file.
2020-07-31 06:00 AM
2020-07-31 06:07 AM
Barry wrote:Thank you! Maybe I haven't explain it clearly: I am writing an addon which should update itself. However, I couldn't find an api to do that. Is there a way to achieve that goal using the given apis?
Try the Add-on Manager - it is part of Archicad.
It may depend on the add-on you are trying to stop.
If it can't be done here you have to close Archicad and delete or move the file from the add-on folder manually.
2020-07-31 07:04 AM
2020-07-31 10:13 AM
2020-07-31 11:15 AM
Ralph wrote:OK. Thank you.
I don't know any way to do this. Given the way Archicad calls the sequence ofCheckEnvironment, RegisterInterfaceand Initializeduring startup, I suspect you wouldn't be able to integrate the update into an active session anyway.
We've written our installer to check if the target version of Archicad is running and ask them to quit first if it is. In the current application structure, I don't think self-updating is possible.
2020-08-13 05:29 AM
