2026-06-24 10:52 AM
Hi everyone,
Is there any native way in the Archicad API (C++ or JSON-RPC) to programmatically capture or export the current active view (2D or 3D) directly into an image file (PNG/JPG)?
If a direct API doesn't exist, what is the recommended standard workaround to achieve this?
Thank you!
2026-06-25 08:36 AM
I am consulting with the developers, I'll come back to you soon.
Regards,
Tamás
2026-06-27 06:53 AM
Hi Tamás,
Thank you for the update. I look forward to hearing back from you and the development team.
Best regards,
2026-06-29 02:30 PM
As far as the developers could find, there is no direct way of exporting a view as an image.
There is a workaround, unfortunately this one has to modify the plan file. You can create a layout, and save it as an image instead of pdf.
Best regards,
Tamás
2026-06-29 02:32 PM
Did you try this addon? https://bimdots.com/product/ai-labs/
