3 weeks ago
Hi everyone,
Is there any native way in the Archicad API (C++ or JSON-RPC) to programmatically capture or export the current active view (2D or 3D) directly into an image file (PNG/JPG)?
If a direct API doesn't exist, what is the recommended standard workaround to achieve this?
Thank you!
3 weeks ago
I am consulting with the developers, I'll come back to you soon.
Regards,
Tamás
3 weeks ago
Hi Tamás,
Thank you for the update. I look forward to hearing back from you and the development team.
Best regards,
3 weeks ago
As far as the developers could find, there is no direct way of exporting a view as an image.
There is a workaround, unfortunately this one has to modify the plan file. You can create a layout, and save it as an image instead of pdf.
Best regards,
Tamás
3 weeks ago
Did you try this addon? https://bimdots.com/product/ai-labs/
