Archicad C++ API
Is there the limit of character length in .grc file?
When I edit the .grc file,e.g I compile the code. the error occur, But I set the less characters, these is not error. I want to know whether there is the limit of chinese characters in grc file.
thanks.
Tibor Lorantfy
We were not able to reproduce your issue. It built successfully for us without any errors.
Please make sure that your GRC file's encoding is "UTF-8 with BOM".
11 REPLIES 11
akomporday
Hi DevJeer,
Could you please upload the file or copy-paste the relevant part here, so I can try to reproduce the error?
Hi akomporday ,
The relevant code :
'GDLG'  ID_DIALOG_FILE_RENAME  Modal | noGrow    100   100  720  734  "ę–‡ä»¶å‘½åé…ē½®" {
/* [  1] */ Button				  554   694   78   30	LargePlain  "äæå­˜"
/* [  2] */ Button				  642   694   78   30	LargePlain  "å–ę¶ˆ"
/* [  3] */ Button				  466   694   78   30	LargePlain  "应用"
/* [  4] */ TextEdit				15   42   400   30	LargePlain  100
/* [  5] */ CheckBox				15   99  200   30	LargePlain	"åÆē”Øå­—ē¬¦åˆ†éš”ē¬¦"
/* [  6] */ PopupControl		    15    163  150   30	 80  3
/* [  7] */ PopupControl		    185    163  150   30	 80  3
/* [  8] */ LeftText			  15   20   84   20	LargePlain  "ę€»ę–‡ä»¶å¹³é¢åē§°"
/* [  9] */ LeftText			  15   141   60   20	LargePlain  "å­—ē¬¦åˆ†éš”ē¬¦"
/* [  10] */ LeftText			  185   141   72   20	LargePlain  "å»ŗē­‘ē¼–å·ęŽ’åŗ"
Thanks.
Tibor Lorantfy
thanks
Thanks. My grc file's encoding is "UTF-8 with BOM". But Often "illegal character" error occurs when there are many chinese characters in my grc file.
The error occurs in ***.grc.rc2.i file. How can I solve it ?
leilei
When you make a compilation error, put a space after the Chinese character.I compiled it in this way.
This problem occurs in Simple Chinese version of vs studio.
Thank you very much.
According to your method, this problem is solved.
Besides, I use Simple Chinese version of vs 2015.But I install the English Language pack ,the problem also occurs. I think the problem may be not caused by the vs language version ?
Akos Somorjai
How do you you call ResConv in the custom build step of your .grc file?
Thanks, Akos
Thanks, Akos
My method that call ResConv is:
cl /nologo /X /EP /P /I "..\..\Support\Inc" /I "..\..\Support\Modules\DGLib" /I ".\Src" /FI"..\..\Support\Inc\utf8header.h" /DDEBUG /DWINDOWS /Fi"$(OutDir)\RO\$(ProjectName).grc.rc2.i" "RINT\$(ProjectName).grc"
"..\..\Support\Tools\Win\ResConv.exe" -m r -D WINDOWS -T W -q utf8 1252 -i "$(OutDir)\RO\$(ProjectName).grc.rc2.i" -D _DEBUG -o "$(OutDir)\RO\$(ProjectName).grc.rc2"
