Archicad C++ API
Is there the limit of character length in .grc file?
When I edit the .grc file,e.g I compile the code. the error occur, But I set the less characters, these is not error. I want to know whether there is the limit of chinese characters in grc file.
thanks.
11 REPLIES 11
Akos Somorjai
In the second line try replacing the '1252' with 'utf8', so that the ResConv compiler produces utf8 output.
Best, Akos
Best, Akos
Thanks.
But the problem also occurs.
