ReignBough
Layout ID, bug?
I created a subset with the following ID settings (using API):
subset.customNumbering = true;
subset.useUpperPrefix = false;
subset.addOwnPrefix = false;
subset.numberingStyle = API_NS_noID;
Then, I created a layout with API_DatabaseInfo->ref set to "Cust002".
db_info.typeID = APIWind_LayoutID;
swprintf(db_info.ref, L"Cust002");
swprintf(db_info.name, L"Test Layout");
db_info.masterLayoutUnId = iMasterLayout;
err = ACAPI_Database(APIDb_NewDatabaseID, &db_info, &parent);
But when the layout was created, the ID is empty. Also in Layout Settings dialog, 'Use Automatic Book and Subset ID assignment' is checked and 'Custom ID' is unchecked.
Is this a bug? If not, is there another way to set the ID (custom ID) without going to navigator item?
Thanks.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
1 Reply 1
ReignBough
I did the following while waiting for a reply:
API_NavigatorItem new_item;
BNZeroMemory(&new_item, sizeof(API_NavigatorItem));
new_item.mapId = mItemData.mapId;
API_Guid guid = item.guid;
mErr = ACAPI_Environment(APIEnv_GetNavigatorItemID, &guid, &new_item); errln = __LINE__;
if (mErr != NoError) { /* error handle */ }
API_DatabaseUnId db_unid = item.db.databaseUnId;
API_LayoutInfo layout_info;
mErr = ACAPI_Environment(APIEnv_GetLayoutSetsID, &layout_info, &db_unid);
layout_info.customLayoutNumbering = true;
sprintf(layout_info.customLayoutNumber, iUiid);
mErr = ACAPI_Environment(APIEnv_ChangeLayoutSetsID, &layout_info, &db_unid); errln = __LINE__;
This will modify the uiid of the layout.
~ReignBough~
