Modeless or Palette Dialog help
Hi
hope someone can help me with a Modeless or Palette Example Code.
I understand how to create a modal dialog but not modeless/palette. I want a palette dialog to have buttons. so far I can't get the dialog to response to the button click event. my code goes to the DG_MSG_INIT of the callback than leaves the function altogether never to return.
1 Reply 1
Tibor Lorantfy
I think you forgot to call ACAPI_RegisterModelessWindow function in DG_MSG_INIT, that's why you won't get any further messages.
I wrote you an example code to show a simple palette with 2 buttons:
// Note that dialID could be different from dialog's resourceID
static short	myDialID = 0;
static GSErrCode __ACENV_CALL	PaletteAPIControlCallBack (Int32 referenceID, API_PaletteMessageID messageID, GS::IntPtr /*param*/)
	if (referenceID == myDialID) {
		switch (messageID) {
			case APIPalMsg_ClosePalette:		DGModelessClose (myDialID);
												break;
			case APIPalMsg_HidePalette_Begin:	DGHideModelessDialog (myDialID);
												break;
			case APIPalMsg_HidePalette_End:		DGShowModelessDialog (myDialID, DG_DF_FIRST);
												break;
			case APIPalMsg_DisableItems_Begin:
			case APIPalMsg_DisableItems_End:	// actually do nothing, because the input finish functionality the buttons have to stay enabled
			case APIPalMsg_IsPaletteVisible:
			case APIPalMsg_OpenPalette:			break;
	return NoError;
// 'GDLG' resource in (RINT) .grc file
'GDLG'  32400  Palette | leftCaption | grow | close      0    0  196   28  "Example Palette" {
/* [  1] */ Button				  88    4   70   20	LargePlain  "Close"
/* [  2] */ Button				   8    4   70   20	LargePlain  "Update"
const short CloseButtonID	= 1;
const short UpdateButtonID	= 2;
// Callback function for the palette
static short DGCALLBACK CntlDlgCallBack (short message, short dialID, short item, DGUserData /*userData*/, DGMessageData msgData)
	switch (message) {
		case DG_MSG_INIT:
			DGSetFocus (dialID, DG_NO_ITEM);
			if (ACAPI_RegisterModelessWindow (dialID, PaletteAPIControlCallBack,
						API_PalEnabled_FloorPlan + API_PalEnabled_Section + API_PalEnabled_Elevation +
						API_PalEnabled_InteriorElevation + API_PalEnabled_Detail + API_PalEnabled_Worksheet + API_PalEnabled_3D + API_PalEnabled_Layout) != NoError)
				DBPrintf ("ACAPI_RegisterModelessWindow failed\n");
			break;
		case DG_MSG_ACTIVATE:		break;
		case DG_MSG_UPDATE:			break;
		case DG_MSG_CHANGE:			break;
		case DG_MSG_DOUBLECLICK:	break;
		case DG_MSG_CLICK:
			switch (item) {
				case UpdateButtonID:	// handle update button click event!
										break;
				case CloseButtonID:
				case DG_CLOSEBOX:
						return item;	// this will result in a DG_MSG_CLOSE message
			break;
		case DG_MSG_GROW:
				short	vgrow = DGGetVGrow (msgData);
				short	hgrow = DGGetHGrow (msgData);
				DGBeginMoveGrowItems (dialID);
				DGMoveItem (dialID, NavCloseButton, hgrow, vgrow);
				DGMoveItem (dialID, NavUpdateButton, hgrow, vgrow);
				DGEndMoveGrowItems (dialID);
			break;
		case DG_MSG_CLOSE:
			ACAPI_UnregisterModelessWindow (myDialID);
			myDialID = 0;
			break;
		default:
			break;
	return (0);
}		// CntlDlgCallBack
// Initialize/open our palette
static bool		Do_PaletteInit (void)
	if (myDialID == 0 || !DGIsDialogOpen (myDialID))
		myDialID = DGModelessInit (ACAPI_GetOwnResModule (), 32400, ACAPI_GetOwnResModule (), CntlDlgCallBack, NULL, 1);
	return myDialID != 0;
}		// Do_PaletteInit
Regards,
Tibor
