Archicad C++ API
SOLVED!
How can I release the restrictions ^DE ^DI ^DD ^DT
nishida_jp
In ArchiCAD 27 API/C++,
the following menu in the grc file imposes restrictions on commands:
'STR#' ID_ADDON_MENU04 "Menu04" {
/* [ ] */ "Construction Support Tool"
/* [ 1] */ "Weight Calculation ^E3 ^ES ^DE ^DI ^DD ^DT ^10004"
How can I release the restrictions ^DE ^DI ^DD ^DT using a button in a modeless dialog during the execution of this menu?
1 ACCEPTED SOLUTION
Solution
Hiromichi Shinkawa
Hi, If you'd control the menu restriction by your C++ code, then I'd suggest you to try the following command:
if (disable)
      itemFlags |= API_MenuItemDisabled;
 else
      itemFlags &= ~API_MenuItemDisabled;
ACAPI_MenuItem_SetMenuItemFlags()
And write enable control code(s) in grc.
HTH.
1 REPLY 1
Solution
Hiromichi Shinkawa
if (disable)
 else
HTH.
