Morph's vertices, coordinates
Hey,
How is it possible to get the vertices of a Morph in AC17? Mostly I read the data through the memo, but this time it doesn't seem to work.
Thanks,
Andor
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Andor,
please try at first with ACAPI_Element_Get3DInfo function.
Example code:
// Dump a vertices of a body (VERT)
static void		DumpVertices (Int32 ibody, const API_Coord& dbOffset)
	API_Component3D 	component;
	Int32				j, nVert;
	API_Tranmat			tm;
	GSErrCode			err;
	WriteReport ("BODY #%d", ibody);
	BNZeroMemory (&component, sizeof (component));
	component.header.typeID = API_BodyID;
	component.header.index  = ibody;
	err = ACAPI_3D_GetComponent (&component);
	if (err != NoError) {
		WriteReport ("    ERROR");
		return;
	nVert = component.body.nVert;
	tm = component.body.tranmat;
	WriteReport ("  VERTs");
	for (j = 1; j <= nVert; j++) {
		component.header.typeID = API_VertID;
		component.header.index  = j;
		if (err == NoError) {
			API_Coord3D	trCoord;	// world coordinates
			trCoord.x = tm.tmx[0]*component.vert.x + tm.tmx[1]*component.vert.y + tm.tmx[2]*component.vert.z + tm.tmx[3];
			trCoord.y = tm.tmx[4]*component.vert.x + tm.tmx[5]*component.vert.y + tm.tmx[6]*component.vert.z + tm.tmx[7];
			trCoord.z = tm.tmx[8]*component.vert.x + tm.tmx[9]*component.vert.y + tm.tmx[10]*component.vert.z + tm.tmx[11];
			trCoord.x += dbOffset.x;
			trCoord.y += dbOffset.y;
			WriteReport ("    [%2d]  (%lf, %lf, %lf)",
						 j,
						 trCoord.x, trCoord.y, trCoord.z);
	return;
}		// DumpVertices
err = ACAPI_Element_Get3DInfo (elemHead, &info3D);
if (err == APIERR_BADID) {
	WriteReport_Alert ("This element does not have 3D information.");
	return;
	ErrorBeep ("Error in ACAPI_Element_Get3DInfo", err);
	return;
for (Int32 ibody = info3D.fbody; ibody <= info3D.lbody; ibody++)
	DumpVertices (ibody, dbOffset);
You can find a good example in the 3D_Test example Add-On.
Regards,
Tibor
