Outdated Add-on
I developed an add-on that was built using the API DevKit 18 (on a windows 8.1 machine), and works on ArchiCAD 18 on some of my machines. I tried it on two machines using windows 8.1 and it worked. However, when I tried loading the add-on on ArchiCAD 18 on windows 7 and windows 10, I get the error of outdated add-on.
Does anyone know a solution to this problem?
Thank you,
Xylios
2 Replies 2
It might be a problem with the installed VS 2010 runtime - refer to this topic.
Ralph Wessel BArch
Central Innovation
Thank you for your reply.
I just finished testing a new addon and it worked.
My solution was based on this post:
http://archicad-talk.graphisoft.com/viewtopic.php?t=28755&highlight=outdated
and I was creating the addon using a Debug build, had to switch to a Release build, and it is working!
Once again, thank you for the reply, best regards,
Xylios
