2021-12-06 07:52 AM
I used DG::Palette for an addon and observed it auto re-opens after being closed, when I change to certain views. These are the steps to reproduce the scenario:
This can be tested with the example addon DG_Test > OwnerDrawnListBoxPalette
This however does not happen with the 'Favorites' palette, for example. I want the addon palette to behave like that.
Anyone any idea?
Thanks.
Dushyant
Solved! Go to Solution.
2022-01-03 01:13 PM
Some additional flagging is missing from the palette (DG_Test/OwnerDrawnListBoxPalette) code. The palette state should be stored before the palette temporarily goes to/comes back from hidden state due to window switching.
A static bool variable can be used to temporarily store the visibility state (paletteOpenAtClose):
GSErrCode __ACENV_CALL OwnerDrawnListBoxPalette::PaletteAPIControlCallBack (Int32 referenceID, API_PaletteMessageID messageID, GS::IntPtr param)
static bool paletteOpenAtClose = false;
GSErrCode err = NoError;
if (referenceID == OwnerDrawnListBoxPalette::ODLBPaletteRefId ()) {
OwnerDrawnListBoxPalette& palette = OwnerDrawnListBoxPalette::GetInstance();
switch (messageID) {
case APIPalMsg_ClosePalette:
case APIPalMsg_HidePalette_Begin:
if (palette.IsVisible()) {
paletteOpenAtClose = true;
palette.Hide();
} else {
break;
case APIPalMsg_OpenPalette:
// no break
case APIPalMsg_HidePalette_End:
if (paletteOpenAtClose && !palette.IsVisible()) {
palette.Show ();
break;
case APIPalMsg_DisableItems_Begin:
palette.DisableItems();
break;
case APIPalMsg_DisableItems_End:
palette.EnableItems();
break;
case APIPalMsg_IsPaletteVisible:
(*reinterpret_cast<bool*> (param)) = palette.IsVisible();
break;
default:
break;
return err;
2022-01-03 01:13 PM
palette.Hide();
} else {
break;
// no break
palette.Show ();
break;
break;
break;
break;
default:
break;
return err;
2022-01-03 01:24 PM
@Miklos Vegh That works perfectly! Thanks a tonne!!
