Plugin\plugin button disabled in South Elevation/3D All/Action Center and other view
Hello everybody. I have a problem. My plugin/plugin button is disabled in South Elevation / 3D All / Action Center views, but everything works fine in the ground floor view. Tell me why this is happening?? Thx
1 Solution
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Konstantin wrote:
In my plugin I get doors :
GS::Array<API_Guid> elementList;
 ACAPI_Element_GetElemList(API_DoorID, &elementList, APIFilt_OnVisLayer);
In 3D window view or Ground Floor I successfully getting the data list, but in Elevations my doors list is empty.
How can I get data in Elevations windows or other(Worksheets/Welcome ...)? Can I somehow get a document and get all the information I need from it, for example, a door?
In Section or Elevation windows there are no doors and windows, you can see only section elements instead (type is API_SectElemID). The parent of the section elements are the doors/windows/etc., see this code:
static GS::Array<API_Guid> GetElemListByTypeFromSectionElevation (API_ElemTypeID elemTypeId)
	GS::Array<API_Guid> result;
	GS::Array<API_Guid> sectElemList;
	ACAPI_Element_GetElemList (API_SectElemID, &sectElemList, APIFilt_OnVisLayer);
	for (const API_Guid& sectElemGuid : sectElemList) {
		API_Element elem = {};
		elem.header.guid = sectElemGuid;
		ACAPI_Element_Get (&elem);
		if (elem.sectElem.parentID == elemTypeId) {
			result.Push (elem.sectElem.parentGuid);
	return result;
// Usage
API_WindowInfo	currWindowInfo = {};
ACAPI_Database (APIDb_GetCurrentWindowID, &currWindowInfo);
static const GS::HashSet<API_WindowTypeID> sectElemOnlyWindows = {
	APIWind_SectionID,
	APIWind_ElevationID,
	APIWind_InteriorElevationID
if (sectElemOnlyWindows.Contains (currWindowInfo.typeID)) {
	elementList = GetElemListByTypeFromSectionElevation (API_DoorID);
} else {
	ACAPI_Element_GetElemList (API_DoorID, &elementList, APIFilt_OnVisLayer);
Go to post
4 Replies 4
Viktor Kovacs
You can specify in the grc file where your command will be available. The magically looking tokens (E3, ES, etc.) are for this purpose.
'STR#' ID_ADDON_MENU "Strings for the Menu" {
/* [  1] */		"Example AddOn Command... ^E3 ^ES ^EE ^EI ^ED ^ET ^10001"
You can check the complete list here:
http://download.graphisoft.com/ftp/techsupport/documentation/developer_docs/APIDevKit51/APIHTMLLibra...
Thanks a lot, it really works. But now I have a new question.
In resources, I used "^ES^EE^EI^ED^EW^E3^EL" and I can call my plugin. In 3D window view or Ground Floor I successfully getting the data list, but in Elevations my doors list is empty.
Viktor Kovacs
Archicad API commands are context sensitive. It means that you can't access the same data from every window. This is why usually it's a good idea to make commands work over floor plan only (some of the internal commands work this way, too).
When you are over a section window, you can access only the elements on that section. It is possible to switch to floor plan database, access the elements and switch back to the original database, but I don't recommend this workflow. If it's not a strong requirement to make it work over sections, it's a better choice to disable it.
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
	return result;
// Usage
	APIWind_SectionID,
} else {
