Archicad C++ API
Problem of using ACAPI_Element_Edit on DetailElement
We attached door and detail after creating detailElement using
err = ACAPI_Element_Create(&detailElement, &memo);
if(err == noErr)
	GSFlags flags = EDITELEMS | DELETEELEMS;
	err = ACAPI_Element_Link(doorElement.header.guid, detailElement.header.guid, flags);
	if(err != noErr)
		GiveMsg_Err("Problem createing link in InsertDetail().\n\nPlease see your CAD Supervisor.\n", err);
detailElement is created and liked without errors.
If I draged my door element I am trying to drag detail element useing fallowing code.
GSErrCode DoEditElement(API_Guid paramsUNotifyGuid, API_ElemTypeID paramsUNotifyTypeID)
API_ActTranPars actTranPars;
API_EditPars editPars;
	switch (paramsUNotifyTypeID)
	case API_DoorID:
		err = ACAPI_Element_GetLinks (element.header.guid, &linkGuids, &nLinks);
		if(err == noErr && !(linkGuids == NULL || nLinks == 0))
			ACAPI_Notify_GetTranParams (&actTranPars);
			ActTranPars_To_EditPars (&actTranPars, &editPars);
			API_Elem_Head**	elemHeadHdl = NULL;
			err = ACAPI_Database (APIDb_GuidToElemHeadID, (void*) linkGuids, (void*) &elemHeadHdl);
			if (err == noErr && elemHeadHdl != NULL)
				API_Neig**	neigHdl = reinterpret_cast<API_Neig**> (BMAllocateHandle (nLinks * sizeof (API_Neig), ALLOCATE_CLEAR, 0));
				if (neigHdl == NULL)
					return APIERR_MEMFULL;
				for (GSIndex index = 0; index < nLinks; index++)
					ElemHead_To_Neig ((*neigHdl) + index, (*elemHeadHdl) + index);
				err = ACAPI_Element_Edit (neigHdl, nLinks, &editPars); // noErrors
				BMKillHandle (reinterpret_cast<GSHandle*> (&elemHeadHdl));
				BMKillHandle (reinterpret_cast<GSHandle*> (&neigHdl));
bool ActTranPars_To_EditPars(const API_ActTranPars *actTranPars, API_EditPars *editPars)
	BNZeroMemory (editPars, sizeof (API_EditPars));
	editPars->withDelete = true;
	editPars->typeID = (API_EditCmdID) 0;
	switch (actTranPars->typeID) {
		case APIEdit_Drag:
			editPars->typeID = APIEdit_Drag;
			editPars->endC.x = actTranPars->theDisp.x;
			editPars->endC.y = actTranPars->theDisp.y;
			editPars->endC.z = actTranPars->theDispZ;
			break;
		case APIEdit_Rotate:
			editPars->typeID = APIEdit_Rotate;
			editPars->origC = actTranPars->theOrigo;
			editPars->begC.x = editPars->origC.x + 1.0;
			editPars->begC.y = editPars->origC.y;
			editPars->endC.x = editPars->origC.x + actTranPars->theCosA;
			editPars->endC.y = editPars->origC.y + actTranPars->theSinA;
			break;
		case APIEdit_Mirror:
			editPars->typeID = APIEdit_Mirror;
			editPars->begC.x = actTranPars->theOrigo.x;
			editPars->begC.y = actTranPars->theOrigo.y;
			editPars->endC.x = actTranPars->theOrigo.x + actTranPars->theAxeVect.x;
			editPars->endC.y = actTranPars->theOrigo.y + actTranPars->theAxeVect.y;
			break;
		case APIEdit_Stretch:
			editPars->typeID = APIEdit_Stretch;
			editPars->endC.x = actTranPars->theOrigo.x + actTranPars->theDisp.x;
			editPars->endC.y = actTranPars->theOrigo.y + actTranPars->theDisp.y;
			break;
		case APIEdit_PDirStretch:
			editPars->typeID = APIEdit_PDirStretch;
			break;
		case APIEdit_PHeightStretch:
			editPars->typeID = APIEdit_PHeightStretch;
			break;
		case APIEdit_Resize:
			editPars->typeID = APIEdit_Resize;
			editPars->endC.x = actTranPars->theOrigo.x + 1;
			editPars->endC.y = actTranPars->theOrigo.y;
			editPars->endC2.x = actTranPars->theOrigo.x + actTranPars->theRatio;
			editPars->endC2.y = actTranPars->theOrigo.y;
			break;
		case APIEdit_Elevate:
			editPars->typeID = APIEdit_Elevate;
			break;
		case APIEdit_VertStretch:
			editPars->typeID = APIEdit_VertStretch;
			break;
	return editPars->typeID != (API_EditCmdID) 0;
But at the end detail is not moving on the plan.
Please any one give me what went wrong?
0 REPLIES 0
