‎2019-11-14
11:28 PM
‎2022-09-29
10:01 AM
Daniel Kassai
/// @param path the path on the filesystem to the GDL to import
/// @param library_folder path within the embedded library to import the item to
GS::Int32 Archlog_import::add_to_embedded_library(const IO::Location &path, const IO::RelativeLocation &library_folder)
if (path.IsEmpty()) {
return -2;
GS::Array<API_LibraryInfo> activeLibs;
GSErrCode err;
GS::Int32 embeddedLibraryIndex = -1;
err = ACAPI_Environment(APIEnv_GetLibrariesID, &activeLibs, &embeddedLibraryIndex);
if (err != NoError || embeddedLibraryIndex == -1) {
// no embedded library
return -4;
IO::Location embedded_folder = activeLibs[embeddedLibraryIndex].location;
IO::RelativeLocation folders(IO::Name("Arch-LOG"));
folders.Append(library_folder);
for (USize i = 0; i < folders.GetLength(); ++i) {
IO::Name folder;
folders.GetName(i, &folder);
embedded_folder.AppendToLocal(folder);
err = ACAPI_Environment(APIEnv_CreateFolderInLibraryID, &embedded_folder);
if (err != NoError) {
return -5;
GS::Array<IO::Location> fileToCopy;
fileToCopy.Push(path);
bool overwrite=true;
err = ACAPI_Environment(APIEnv_CopyFilesIntoLibraryID, &embedded_folder, &fileToCopy, &overwrite);
return -6;
IO::Location embedded_file(embedded_folder);
IO::Name name;
path.GetLastLocalName(&name);
embedded_file.AppendToLocal(name);
API_LibPart libPart;
BNZeroMemory(&libPart, sizeof(API_LibPart));
libPart.typeID = APILib_ObjectID;
libPart.location = &embedded_file;
err = ACAPI_LibPart_Register(&libPart);
return err == NoError ? 0 : -7;
Is there some additional step we need to take to get the script to execute? Note that setting the part typeID to macro doesn't help.‎2019-11-16 02:00 PM
‎2019-11-18 03:36 AM
‎2019-11-18 04:44 AM
‎2019-11-18 08:35 AM
‎2019-11-20 01:55 AM
‎2019-12-02 01:47 PM
