ReignBough
Purged attribute list without purging the attribute
Is there a way to get the list of all attributes used in the project without purging the attributes.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
3 Replies 3
Akos Somorjai
Yes, there's a "Print to FIle..." button in that dialog, that allows you to save the list. If you switch to the All tab, then you'll get all the attributes.
Cheers, Akos
ReignBough
I'm sorry, but what I mean is through code. I want to get the list of all the materials being used on a project.
~ReignBough~
Akos Somorjai
There's no simple way to do that. You have to go through all the different element and attribute types, placed objects/windows/doors material attribute parameters etc. Go through all element defaults as well.
You'll also have to switch to the different database types whereever a material might be used.
Best, Akos
