davidevianello
Python Get Building Materials
Hi all,
I'm tring to do my first Python programm running in Archicad.
Everything stops at the beginning with this command:
building_materials = acc.GetBuildingMaterials()
it aswer "AttributeError: 'Commands' object has no attribute 'GetBuildingMaterials'"
I need it to retrive the material index with the floowing commands:
BUILDING_MATERIAL_NAME = "Estrich + Parkett 15 cm"
for bm in building_materials:
    if bm.name == BUILDING_MATERIAL_NAME:
        bm_index = bm.index
        break
Thank you in advance
runxel
Hi Davide, welcome to the forum!
There is no command "GetBuildingMaterials", only "GetBuildingMaterialAttributes". Maybe that solves this already.
Let me also recommend you Tapir; which is not a replacement but enhances the capabilities of the Python connection drastically.
