davidevianello
Python Get Building Materials
Hi all,
I'm tring to do my first Python programm running in Archicad.
Everything stops at the beginning with this command:
building_materials = acc.GetBuildingMaterials()
it aswer "AttributeError: 'Commands' object has no attribute 'GetBuildingMaterials'"
I need it to retrive the material index with the floowing commands:
BUILDING_MATERIAL_NAME = "Estrich + Parkett 15 cm"
for bm in building_materials:
    if bm.name == BUILDING_MATERIAL_NAME:
        bm_index = bm.index
        break
Thank you in advance
1 Reply 1
runxel
Hi Davide, welcome to the forum!
There is no command "GetBuildingMaterials", only "GetBuildingMaterialAttributes". Maybe that solves this already.
Let me also recommend you Tapir; which is not a replacement but enhances the capabilities of the Python connection drastically.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
