‎2022-03-22 05:55 PM - edited ‎2022-03-23 05:54 PM
AC23
Refreshing all layouts is a step in a larger task that will ultimately produce a set of .pdf files of each Architectural layout in a model full of mixed discipline layouts. I started with code found here.
With my edits, I have this:
void RefreshAllLayoutBooks()
API_DatabaseUnId *dbases = NULL;
API_DatabaseInfo db_orig, dbLayoutBook;
GSErrCode err;
Int32 nDbases = 0;
Int32 intCount = 0;
err = ACAPI_Database(APIDb_GetCurrentDatabaseID, &db_orig, NULL);
if(err != NoError)
return;
err = ACAPI_Database(APIDb_GetLayoutDatabasesID, &dbases, NULL);
if (err == NoError)
nDbases = BMpGetSize(reinterpret_cast<GSPtr>(dbases)) / sizeof(API_DatabaseUnId);
for (Int32 ii = 0; ii < nDbases; ++ii)
BNZeroMemory(&dbLayoutBook, sizeof(API_DatabaseInfo));
dbLayoutBook.typeID = APIWind_LayoutID;
dbLayoutBook.databaseUnId = dbases[ii];
intCount = intCount ++;
GS::UniString strMsg;
GS::UniString strBlank;
if (intCount < 10) {
strBlank = " ";
else if (intCount < 100) {
strBlank = " ";
else if (intCount < 1000) {
strBlank = " ";
err = ACAPI_Database(APIDb_GetDatabaseInfoID, &dbLayoutBook, NULL);
if (err == NoError) {
if (dbLayoutBook.ref != GS::UniString("")) {
GS::UniString strSheetName = dbLayoutBook.ref;
if (strSheetName.GetSubstring(0, 1) == "A") {
strMsg = strBlank + GS::UniString::Printf("%d", intCount);
strMsg = "..." + strMsg + " " + strSheetName;
ACAPI_WriteReport(strMsg, false);
else {
strMsg = strBlank + GS::UniString::Printf("%d", intCount) + GS::UniString(" N.O.T.H.I.N.G");
strMsg = "+++" + strMsg;
ACAPI_Database(APIDb_ChangeCurrentDatabaseID, &dbLayoutBook, nullptr);
ACAPI_Database(APIDb_RebuildCurrentDatabaseID);
if (dbases != NULL)
BMpFree(reinterpret_cast<GSPtr>(dbases));
The output of the above code is:
... 2 A002
... 5 A001
+++ 7 N.O.T.H.I.N.G
+++ 8 N.O.T.H.I.N.G
... 131 A123
... 132 A200
... 133 A311
... 134 A110a
... 135 A101
etc.
This confirms for me that I am on the right track for capturing only the Architectural sheets in the model. And capturing/not processing a sheet that has no discipline assigned to it. [Not sure what that is all about yet]. The number between the "..." and the sheet number is only a sequential number that is incremented as I examine each layout for inclusion in the set of Architectural sheets.
I am having trouble understanding why the update of the layouts with:
does not occur. I am verifying the update by adding a couple of random walls and verifying success of this process with a manual update.
my problem:
I believe I have not captured the proper database ID and/or have not set it as current. Maybe the choice of functions used is not correct. I am not sure. Any direction provided would be helpful.
Thanks,
chris
‎2022-03-25 06:48 AM - edited ‎2022-04-18 04:18 PM
Update Page Layout with Metadata API (using REST API). Hi everyone! I need to add new account custom fields to the account page layout.
