2026-04-24 10:14 AM
Hi, we would like to have an automated GDL object that displays only the first 2 characters of the Layout ID no.
I want to place the GDL object on a Master Layout. I have only managed to get it working with placing an object on the layout itself but that's not very helpful.
Example:
Solved! Go to Solution.
2026-04-26 03:40 PM
Yeah I think that is not doable right now.
You can either use the Autotext, which of course is not usable as a GDL string, so you'd have the full Layout ID, or you use the request value, but that one is not being passed through (which is actually a feature rather than a bug).
I'd go with the object on the layout, even if it needs a bit of work to keep track of it.
2026-04-26 03:40 PM
2026-04-26 05:14 PM
Or place autotext on the master and add a white fill with white perimeter to cover the second half of the layout name.
It might be a bit of trial and error to get the fill position, or use trace & reference to help.
2026-04-27 09:14 AM
Thats a shame, thank you for answering.
2026-04-28 11:40 AM - edited 2026-04-28 11:44 AM
2026-04-29 02:03 PM
Hi, thank you. Unfortunately it can only display the master-layoutname when placed on the masterlayout.
2026-05-01 05:38 AM
I have hotspots on a few of my masters for placement position of specific objects that pull info from the layout...
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2026-05-04 11:59 AM
Could you please elaborate on how those hotspots pull info from the layout and how it works in general? I'm curious about the workflow.
2026-05-05 03:19 AM
The Hotspots don't... I just use them as positioning guides to place objects that do on the layouts... My titleblocks have Worksheet elements, which I could probably do away with, Master Layout elements and Layout elements... This has resulted in one person issuing a drawing with on of the objects missing before, since they made a new layout instead of duplicating one, and did not know what needed to be placed... So, far from ideal...
Ling.
