‎2007-11-07
11:07 AM
‎2023-08-04
04:16 PM
Doreena Deng
‎2007-11-07 10:45 PM
‎2007-11-07 11:19 PM
Joseph wrote:Yes, the version currently available for download is fine under 10.5
Ralph,
Is Objective updated for that? I am trying to jump in 10.5.
Joseph
‎2008-02-26 08:07 AM
‎2008-02-26 10:10 AM
Ferenc wrote:You shouldn't have to do anything special or different with XCode. Is there any chance the resources aren't included in the final build?
Any idea why the MDID numbers which work on the Windows XP VisualStudio version won't work on the XCODE version?
(this Add-on can't be verified, please ask the distributor) Is there some word swapping/byte swapping to be done to work on the Intel Macs (Leopard/Xcode)?
‎2008-02-26 03:58 PM
‎2008-02-27 09:58 AM
Ferenc wrote:I modified Plan_DumpFix.grc to look something like the following and it worked (obviously those aren't the real ID's though):
That's exactly what I'm trying first (PlanDump).
And that's giving me the message above when attempting to load (Options/Add-Ons Manager)
Since it looks like the the MDID_APICD.H has a slightly different format for the GCC compiler I'm thinking it might be the decimal representation of a four byte long integer might be a problem, or the byte/word swapping.
Thanks for the reply.
// Non-localizable resource description for the Plan Dump Add-On
// API Development Kit 11; Mac/Win
// Namespaces: Contact person:
// -None-
// [SG compatible] - Yes
'MDID' 32500 "Add-On Identifier" {
1234 /* Developer ID */
56789 /* Add-on ID */
Does this work for you?
‎2008-02-27 04:43 PM
‎2008-02-27 05:10 PM
Ferenc wrote:You could check the contents of the add-ons resources using a utility in Apple's Developer kit called "DeRez"
How do you verify it under mac osx (leopard, intelmac)?
Or you just load it and it works (as in windows)?
DeRez -useDF /Applications/Graphisoft/ArchiCAD\ 11/Add-Ons/Plan_Dump.apx/Contents/Resources/Plan_Dump.rsrcEnter the path to your build of the Plan_Dump add-on in the above statement naturally. You should then be able to determine if the built product has an MDID resource and confirm the values are correct.
‎2008-02-27 05:17 PM
