Archicad C++ API
!Restored: Add-Ons under Leopard
Ralph Wessel
Mentor
I've posted this under other topics, but it might be missed by developers who don't use ArchiCAD for architectural work. Under macOS 10.5, ArchiCAD will not recognise a bundle as an add-on if it lacks a 'PkgInfo' resource. Make sure you check the option 'Force Package Info Generation' in XCode (sets GENERATE_PKGINFO_FILE=YES).
Note that this option isn't set in the example files in the DevKit.
Ralph Wessel BArch
Central Innovation
10 REPLIES 10
breakthrough!
Thanks for your help.
DeRez worked as you told me, except in the command line the bundle name is plan_dump.bundle not plan_dump.apx
I think I still have some problem with the updating via incremental build, so I did (not too scientifically) Clean All and then Build, which created a fresh version of the .rsrc file
Thanks again...
moving along....
