2014-06-23
08:58 PM
- last edited on
2023-08-01
02:52 PM
by
Doreena Deng
2014-06-25 04:24 PM
// Create a Single-plane Roof
void Do_CreatePlaneRoof (API_Coord centerPoint)
API_Element element;
BNZeroMemory (&element, sizeof (API_Element));
element.header.typeID = API_RoofID;
element.roof.roofClass = API_PlaneRoofID;
GSErrCode err = ACAPI_Element_GetDefaults (&element, NULL);
if (err != NoError) {
ErrorBeep ("ACAPI_Element_GetDefaults (roof)", err);
return;
API_ElementMemo memo;
BNZeroMemory (&memo, sizeof (API_ElementMemo));
// constructing planeRoof data
element.roof.u.planeRoof.poly.nCoords = 8;
element.roof.u.planeRoof.poly.nSubPolys = 2;
element.roof.u.planeRoof.poly.nArcs = 2;
memo.coords = reinterpret_cast<API_Coord**> (BMAllocateHandle ((element.roof.u.planeRoof.poly.nCoords + 1) * sizeof (API_Coord), ALLOCATE_CLEAR, 0));
memo.pends = reinterpret_cast<Int32**> (BMAllocateHandle ((element.roof.u.planeRoof.poly.nSubPolys + 1) * sizeof (Int32), ALLOCATE_CLEAR, 0));
memo.parcs = reinterpret_cast<API_PolyArc**> (BMAllocateHandle (element.roof.u.planeRoof.poly.nArcs * sizeof (API_PolyArc), ALLOCATE_CLEAR, 0));
if (memo.coords == NULL || memo.pends == NULL || memo.parcs == NULL) {
ErrorBeep ("Not enough memory to create roof polygon data", APIERR_MEMFULL);
ACAPI_DisposeElemMemoHdls (&memo);
return;
// contour points:
(*memo.coords)[1].x = centerPoint.x + 10.0;
(*memo.coords)[1].y = centerPoint.y + 10.0;
(*memo.coords)[2].x = centerPoint.x + 10.0;
(*memo.coords)[2].y = centerPoint.y - 10.0;
(*memo.coords)[3].x = centerPoint.x - 10.0;
(*memo.coords)[3].y = centerPoint.y - 10.0;
(*memo.coords)[4].x = centerPoint.x - 10.0;
(*memo.coords)[4].y = centerPoint.y + 10.0;
(*memo.coords)[5] = (*memo.coords)[1];
(*memo.pends)[1] = 5;
// hole points:
(*memo.coords)[6].x = centerPoint.x + 5.0;
(*memo.coords)[6].y = centerPoint.y + 0.0;
(*memo.coords)[7].x = centerPoint.x - 5.0;
(*memo.coords)[7].y = centerPoint.y + 0.0;
(*memo.coords)[8] = (*memo.coords)[6];
(*memo.pends)[2] = 8;
// arcs:
(*memo.parcs)[0].begIndex = 6; // makes a circle-shaped hole
(*memo.parcs)[0].endIndex = 7;
(*memo.parcs)[0].arcAngle = PI;
(*memo.parcs)[1].begIndex = 7;
(*memo.parcs)[1].endIndex = 8;
(*memo.parcs)[1].arcAngle = PI;
// roof baseline
element.roof.u.planeRoof.baseLine.c1.x = (*memo.coords)[1].x;
element.roof.u.planeRoof.baseLine.c1.y = (*memo.coords)[1].y;
element.roof.u.planeRoof.baseLine.c2.x = (*memo.coords)[3].x;
element.roof.u.planeRoof.baseLine.c2.y = (*memo.coords)[3].y;
// roof angle
element.roof.u.planeRoof.angle = 5.0 * DEGRAD;
// create the roof element
err = ACAPI_Element_Create (&element, &memo);
if (err != NoError)
ErrorBeep ("ACAPI_Element_Create (roof)", err);
return;
} // Do_CreatePlaneRoof 2014-07-01 03:05 PM
