Archicad C++ API
[SOLVED] Get Project name in Add-On
Hi
How can I get Project Name or file name in ArchiCAD Add-On?
Thanks
Lukasz
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Lukasz,
You can get informations about the project with the ACAPI_Environment (APIEnv_ProjectID, ...) method call.
API_ProjectInfo		projectInfo;
GSErrCode			err = ACAPI_Environment (APIEnv_ProjectID, &projectInfo, NULL);
if (err != NoError) {
	ErrorBeep ("APIEnv_ProjectID", err);
	return;
if (projectInfo.untitled) {
	WriteReport ("Project file has not been saved yet");
} else {
	IO::Path		projectPath;
	IO::Name		projectName;
	if (!projectInfo.teamwork) {
		projectInfo.location->ToPath (&projectPath);
		WriteReport ("Solo Project location: %s", (const char *) projectPath);
		projectInfo.location->GetLastLocalName (&projectName);
		WriteReport ("Project Name: %s", (const char *) projectName.ToCStr ());
	} else {
		projectInfo.location_team->ToPath (&projectPath);
		WriteReport ("Shared Project: %s", (const char *) projectPath);
		projectInfo.location_team->GetLastLocalName (&projectName);
	if (projectInfo.location != NULL)
		delete projectInfo.location;
	if (projectInfo.location_team != NULL)
		delete projectInfo.location_team;
Regards,
Tibor
5 REPLIES 5
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Lukasz,
	return;
} else {
	} else {
Regards,
Tibor
Thanks for your help. It is working
Best Regards
Lukasz
Hello Tibor,
First of all i'm new here, i've been tinkering around with archicad API for a few days now (so keep in mind i'm still a noob).
I've been trying to get the project's name, as shown in the picture below, the value testtest.
https://drive.google.com/file/d/11gLYinCXFZuUj9C-o8uiFcHBRlnv9aod/view?usp=sharing
I set this value (testtest) manually, and saved the file since, closed it, opened it again, value was still there.
When i try to access it from the addon i'm coding (dev kit 21), i keep getting (null).
Here's how i'm attempting to do this:
GSErrCode			err = ACAPI_Environment(APIEnv_ProjectID,  &projectInfo, NULL);
	ErrorBeep("APIEnv_ProjectID", err);
	return;
	WriteReport("Project file has not been saved yet");
else {
	DBPrintf("\n\nprojectname = %s \n\n", projectInfo.projectName);
When reading this page: http://archicadapi.graphisoft.com/documentation/api_projectinfo
I can't see what i'm doing wrong...
Any help or insights would be much appreciated
Wacim
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Wacim!
Well done, it's nice from a beginner!
The projectName field of the API_ProjectInfo structure is a pointer to a GS::UniString object, which means you can get the "const char*" string from it the following way:
projectInfo.projectName->ToCStr()->Get()
So instead of this:
Use this:
    DBPrintf("\n\nprojectname = %s \n\n", projectInfo.projectName->ToCStr()->Get());
I hope this helps.
Regards,
Tibor
Thanks again Tibor
I finally achieved this with APIAny_GetAutoTextKeysID
great example given here:
http://archicadapi.graphisoft.com/documentation/apiany_getautotextkeysid
