[SOLVED] IFC name
Is it possible to get IFC name from element guid?
5 Replies 5
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Sure, you can get all IFC attributes and properties too!
Here is sample code for getting IFC name from element guid:
bool GetIFCNameFromElementGuid (const API_Guid& element_guid, GS::UniString* ifcName)
	GS::Array<API_IFCAttribute>  attributes;
	ACAPI_Element_GetIFCAttributes (element_guid, &attributes);
	for (GS::Array<API_IFCAttribute>::ConstIterator it = attributes.Enumerate (); it != NULL; ++it) {
		if ((*it).attributeName == "Name") {
			*ifcName = (*it).attributeValue;
			return true;
	return false;
// Usage:
GS::UniString ifcName;
GetIFCNameFromElementGuid (element_guid, &ifcName);
How can it convert GS::UniString to string or char ?
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
You can use ToCStr function like this:
GS::UniString gsUniString ("string_inside");
char* cString = gsUniString.ToCStr ().Get ();
std::string str (gsUniString.ToCStr ());	// std::string str (gsUniString.ToCStr (0, GS::MaxUSize, CC_UTF8));
It didn't work like this, maybe i did something wrong, error: that const char* cannot be used to char*
Managed to work like this :
 char cString[32];
for (int ii=0;ii<32;ii++){
cString[ii] = *gsUniString.ToCStr (ii).Get ();
This way everything worked fine will use function this way.
Again, thanks Tibor .
Found better solution simple just:
 const char* cString = gsUniString.ToCStr().Get();
And everythings works fine
