ReignBough
[SOLVED] Property missing
Assuming that there is initially no property on Property Manager.
  • Create a property on Property Manager.
  • Export the created property.
  • Create a scheme/schedule with criteria of the created property.
  • Delete the create property on Property Manager.
  • Import the exported property.
  • Open schedule. The criteria (with property) is now "Missing".
Why?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
1 Solution
ReignBough
Thanks stefan.
I am trying to create add-on that uses the property. I saved the GUID of the property on a file. I did the process above except that the scheme is the file I created. That's why I found that this is happening on the scheme.
I already created a work around with this problem.
~ReignBough~
Go to post
3 Replies 3
stefan
This is not a developer question, but here it goes:
When you export a property in a schedule to Excel, there is a hidden column with the internal Property ID.
When you delete the Property, it is gone together with the ID.
When you re-import the schedule, ARCHICAD cannot map this property to something that doesn't exist anymore.
If you try to re-create the property, it'll have a different internal ID. So it is lost forever.
You may be able to export your properties to XML, edit the XML to re-enter the old guid and re-import the properties from the XML to re-create the same guid.
Archicad-user since 1998
my Archicad Book
ReignBough
Thanks stefan.
~ReignBough~
davdelven
Hello,
Any improvement on that?
"You may be able to export your properties to XML, edit the XML to re-enter the old guid and re-import the properties from the XML to re-create the same guid."
Thanks
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
