‎2019-07-31
09:31 AM
- last edited on
‎2022-10-04
04:25 PM
by
Daniel Kassai
‎2019-07-31 10:19 AM
‎2019-07-31 10:54 AM
‎2019-07-31 11:12 AM
bool <MyDialogClass>::KeyPressed (const DG::Key::Code&, DG::Item**)
// If my dialog has the focus, then don't allow ARCHICAD to handle the shortcut
short focusID;
DGGetFocus (DG_ALL_DIALOGS, &focusID, nullptr);
if (focusID == GetId ()) {
return true;
return false;
‎2019-07-31 12:58 PM
Tibor wrote:Hm, unfortunately, VFB window is not an ArchiCAD dialog and we are re-using this window across plugins. I'm able to handle events for user gain/loss focus in the text field in that window. Therefore my idea was to tell ArchiCAD there to bypass the shortcuts. Is something like this possible?
Your dialog is a modeless dialog, am I right?
In this case you should inherit your dialog class from DG::LowLevelKeyboardHandler, call InstallHandler(*this) from the constructor, call RemoveHandler(*this) from the destructor and override the KeyPressed function like this:bool <MyDialogClass>::KeyPressed (const DG::Key::Code&, DG::Item**) { // If my dialog has the focus, then don't allow ARCHICAD to handle the shortcut short focusID; DGGetFocus (DG_ALL_DIALOGS, &focusID, nullptr); if (focusID == GetId ()) { return true; } return false; }
‎2019-08-02 11:51 AM
‎2019-08-02 03:58 PM
