Spline: how to determine the number of points?
ArchiCAD API 19.
I need to move and rotate the spline.
Memo contains **coords but where are stored the number of points?
Thank you!)
2 Replies 2
Ralph Wessel
You can get the size of the allocated handle and divide it by the size of a single coordinate, e.g.
BMGetHandleSize((GSHandle) memo.coords) / sizeof(API_Coord)
However, if you want to move and/or rotate the whole spline it would be easier to apply a transformation to the element with ACAPI_Element_Edit and passing the transformation in a API_EditPars structure.
Ralph Wessel BArch
Central Innovation
wow)
Ralph, thank you so much again!)
