ReignBough
TRANMAT Rotation Z
I used the transformation matrix function on AC22:
TRANMAT* tm;
Geometry::TMRotation_Z(tm, radAngle);
This is not existing in AC23 and it seems that the new function is:
TRANMAT* tm;
tm->CreateRotationZ(radAngle);
But this function returns 0 values on tmx.
Is this a bug? Or, am I using this function wrong? Or, am I using the wrong function?
Also, is there a documentation on what are the new TRANMAT functions?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
1 Solution
Akos Somorjai
The correct code would be:
TRANMAT tran = TRANMAT::CreateRotationZ (radAngle);
tran.FillStatus2D ();
Best, Akos
Go to post
Akos Somorjai
Best, Akos
