I'm making a 2D script where I define the side of a square, and then I want to use a FOR-NEXT loop to generate the rest of the square.
I've made two scripts that I think should work exactly the same, but they don't - can anytone illuminate me as to why?
First I made a manual script. This generates a perfect square as intended:
side = 1
LINE2 0, 0, side, 0 ! bottom edge
ADD2 side, 0
ROT2 90
LINE2 0, 0, side, 0 ! right edge
ADD2 side, 0
ROT2 90
LINE2 0, 0, side, 0 ! top edge
ADD2 side, 0
ROT2 90
LINE2 0, 0, side, 0 ! left edge
END
Then I try to make the same script as a FOR-NEXT loop:
side = 1
FOR i = 1 TO 4
ROT2 90*(i-1)
LINE2 0, 0, side, 0
ADD2 side, 0 ! move to the endpoint for the next edge
NEXT i
END
This script only generates the bottom and right edge - why?
I would imagine that increasing i>4 would generate an overlapping loop, but the geometry just keeps getting more and more wonky - what is the logic I'm not getting?
EDIT: 20 seconds after posting I realised I just needed to change the rotation to a simple 90 degrees turn at the bottom of the transformation stack instead of a "fancy" 90*(i-1) at the start.
I don't see a button to delete this post, so I'm leaving it up to be shamed.
Solution:
FOR i = 1 TO 4
LINE2 0, 0, side, 0
ROT2 90
NEXT i
28.3.3 (6300) NOR FULL ● Win 11 Enterprise x64 ● Intel 9 185H @ 2.30GHz ● 64GB ● Nvidia RTX 3000 Ada
