Archicad C++ API
Undefined symbol errors when building add-ons for Archicad 25
I'm trying to build add-ons for Archicad 25 using Xcode. It builds all the files fine, but then comes up with 4 errors related to the RS module. The same add-on builds fine for previous versions of Archicad.
What am I doing wrong?
(I've included the Modules\RS folder in the User Header Search Paths field for the Xcode project. Without that it kicks up errors much earlier in the build process.)
Viktor Kovacs
RS is a new module in Archicad 25. It's not enough to add it to the include search path, you also have to add it to the used libraries/frameworks list.
Viktor Kovacs
Thanks Viktor! That's exactly what I needed to do.
A typical rookie error ...
