chenjie
Why ACAPI_Navigator_GetNavigatorChildrenItems (API_NavigatorItem* item, GS::Array<API_NavigatorItem>
Why ACAPI_Navigator_GetNavigatorChildrenItems (API_NavigatorItem* item, GS::Array<API_NavigatorItem>* items) The order of the returned items does not match the actual order, for example, in the View Mapping Navigator, the actual order of a folder is a plan view and a section view, but the order of the items returned is a section view and a plan view
1 Solution
Tamas Polyak
I've looked into the code, and the order it gets the child items is the physical order, while on the UI it is sorted to be in a different order. You can sort it to the same order in your code. Please refer to the Navigator_Test example project of the API Development Kit.
Regards,
Tamás
Go to post
Tamas Polyak
I'm looking into it, and I'll come back with an answer soon.
Regards,
Tamás
Tamas Polyak
Regards,
Tamás
