Archicad C++ API
Wizard doesnt create reference files
Hello;
a newb here;
I've just tried using the wizard in VS to create my project file
(In visual studio 2015 the "C++ Archicad Add-on").
and it creates the project, but some reference/include files are missing.
is this normal behavior, or am I doing something wrong.
do I need to copy the missing reference files manually, or is there something wrong with the installation?
dfintha
Graphisoft Alumni
Graphisoft Alumni
Where did you place your project files?
If you create an add-on using the wizard, it uses relative paths for libraries and headers, and as such, you should place your add-on's project folder under the path\to\devkit\Examples folder.
Best regards,
Dénes
ah. so that's what I did wrong.
I use my work folder on another drive.
thanks for help. I think there'll be plenty more to come.
