3 weeks ago
bOverridePostSurface / matPost) on Railing sub-elements — Posts, Rails, Panels, etc. — identified by their own GUID (obtained via ACAPI_Element_GetMemo_ExternalHierarchical / the equivalent subelement enumeration).ACAPI_Element_GetMemo(subElemGuid, &memo, APIMemoMask_AddPars) correctly returns the full AddPar list for a sub-element (e.g. 111 parameters for a Post, including bOverridePostSurface/matPost).ACAPI_LibraryPart_OpenParameters (session-based) on the sub-element — fails outright; can't get a session open for this element type.ACAPI_Element_Change(&element, &mask, &memo, APIMemoMask_AddPars, true) directly on the sub-element's own guid — APIERR_BADPARS. (Tried both an empty mask and ACAPI_ELEMENT_MASK_SETFULL.)ACAPI_Element_ChangeParameters(elemGuids, &element, &memo, &mask) — APIERR_BADID.ACAPI_Element_ChangeExt using API_SubElement with subType = APISubElement_RailingPost, called on the owning top-level Railing element — APIERR_BADID, tried both with the sub-element's real GUID set and with the fully-populated API_Element copied into subElem, indices left at subIndex = subSubIndex = 0. Same rejection both times.API_SubElementType defines APISubElement_RailingPost, RailingRail, etc., and API_SubElement::subIndex/subSubIndex's field docs specifically mention Railing — but API_SubElement's own class-level description only lists Window/Door/Section/Elevation/InteriorElevation/ChangeMarker/CurtainWall as the element types supported by ACAPI_Element_GetDefaultsExt/ChangeDefaultsExt/CreateExt/ChangeExt. Railing isn't mentioned there, which would explain the consistent APIERR_BADID.API_RailingPostType/API_RailingNodeType/API_RailingSegmentType/etc. carry a params/AddPar handle anywhere in the struct tree, so there's nothing to modify even via the parent Railing's own memo.ACAPI_Element_ChangeExt is meant to support it, what are the correct semantics for subIndex/subSubIndex for APISubElement_RailingPost specifically (segment index? node index? position within a pattern?), and does subElem's GUID matter at all, or is addressing purely index-based?
a week ago
Hi Mathias,
I've opened a support issue about your question.
Regards,
Tamás
