Archicad C++ API
addon admin tool 4 digits developer Id
Hi Again,
The developer Id that I have is 9 digits but on AddOnAdmin tool, I can enter just 4 digits numbers to developer Id input. What is the difference between them ?
poco2013
Mentor
When using the ADDONADMIN you do not use the developer ID number. Use the 4 letter developer String ID to first make a new database. Afterwards to make a new local ADDON within that database, enter the Authorization string key. which will produce the local add on number. In the Addon code, in the namefix.grc file, you,there, use your longer individual ID number ID and the local AddON number obtained in the ADDONADMIN program.
FYI:
As a alternate, you can now use the developer web site to obtain local ADDON numbers.
Gerry
Thanks Gerry.
