Martin Walter
changing the index of library part does not work
I'm trying to change the library part index of an element by this code:
API_Element elementMask;
BNZeroMemory(&elementMask, sizeof(API_Element));
ACAPI_ELEMENT_MASK_SET(elementMask, API_WindowType, openingBase.libInd);
element.window.openingBase.libInd = iLibIndex;
const GSErrCode error = ACAPI_Element_ChangeParameters({ element.header.guid }, &element, nullptr, &elementMask);
const GSErrCode errorChange = ACAPI_Element_Change(&element, &elementMask, nullptr, 0UL, false);
But I get the result APIERR_BADPARS for both functions ACAPI_Element_ChangeParameters and ACAPI_Element_Change.
AC22-27, Windows 11, i7-1355U, 32GB RAM, 2TB SSD
1 Solution
I think that changing just the index of the library part may not be sufficient. You probably also need to set the correct parameters for that object – possibly that's what the error is indicating.
You could get the correct parameters by loading the default from the object with ACAPI_LibPart_GetParams. The memo data retrieved with this method can be directly used to update the target element, but you might want to use ACAPI_Element_Change in order to write the changes to both the element and memo data.
Ralph Wessel BArch
Central Innovation
Go to post
5 Replies 5
Are you attempting to change the element within an active undo session? Otherwise, what error is returned?
Ralph Wessel BArch
Central Innovation
Martin Walter
Yes I use the command in ACAPI_CallUndoableCommand.
The returned error is APIERR_BADPARS.
Martin Walter
Any ideas?
Ralph Wessel BArch
Central Innovation
Martin Walter
Using the element memo instead of a nullptr was the correct hint. Thanks a lot!
